Why does my 1997 Honda CRV heater not fully work?
My 1997 Honda CRV will not heat up, the blower works and some warm heat will blow through the vents on the dash consul, but nothing but cold air or no air blows out down by my feet. My car no longer heats to the point where I have to turn the heat down, it never warms the entire car, I can drive 30 to 45 minutes to work and by the time I get to work my car is still cold inside.
Bu iyi bir soru mu?
I have similar issue .. I've pulled out the fan to make sure it's not clogged (it was clear). I'm hoping someone could give me some pointers and um sick if being cold in the winter! Like this guy ^^ it produces lukewarm air.
Jordan E McCullough tarafından
@jordars what have you checked thus far? Have you checked your coolant level? What does your temperature gauge show?
oldturkey03 tarafından
It is entirely possible that your heater core is blocked. They get filled with scale and crap. You could back flush it, and that may do the trick, however it could always be your thermostat, not opening as it should. That is what I would check first, as it is the cheapest and easiest.
sm_vulkus tarafından
Hey guys ... I pulled out the fan gave it a clean-up, plan to flash In a few weeks and I'm 100% snowed under with work, studies and family life
