Ana içeriğe geç
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 Soru Tümünü görüntüle
I spilt tea on the back of the MacBook, I heard some noises
I spilt tea on the back of the macbook, i heard some noises of electricity And the screen went off.
I connected it to the charger to see if it is still working or not, and it was charging, then the battery indicator on the left of the macbook went green permanently, only one light is working and it is green
Now the macbook dont start and the battery indicator is still green
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
STOP! disconnect the MagSafe and open your system up following this guide: MacBook Pro 15" Unibody Mid 2012 Logic Board Replacement. Follow the first three Steps. Then jump down to Step24 using the image as a reference do you see any burn't components? Do you see any tea stains?
Your tea has shorted out some of the components we need to figure out whats damaged. If you think this is to much for you you'll need to find someone to fix your system.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
I disconnected it but I can’t do this steps
and i want to know what this battery indicator means? And if the macbook is going to work again or it is dead forever?
tarafından
You'll need to get your system to someone who can repair it. Time is your enemy here! The tea has acids which left on the logic board will damage it. Which is why we need to clean it off ASAP!
What does the battery tester telling you? The batteries charge state. At this point I would disconnect the battery internally! You really don't want the power to be running until you've fixed the system.
Can your system be saved? Hopefully! Without seeing the system I can't tell you how bad it is.
tarafından
Yorum Ekle
Bu cevap aslında başka bir soru için verilmişti.
The tea probably damaged the logic board. You will want t open the device and look for any visible signs of liquid on the board. You can try to clean it off with IPA (>90%) and a soft brush. However, it may have shorted some components in which case this will have to be looked at by a repair shop that does micro-soldering repairs.
Puan 2
Yorum Ekle
Yanıtını ekle
Hiesa sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 34
