Ana içeriğe geç
Steering wheel and pedal by ThrustMaster for the Xbox One gaming console.
19 Soru Tümünü görüntüle
Won’t turn left
My wheel on the game turns fine to the right but won’t turn to the left if you could help that would be awesome. it will only turn a bit when turning to the left all the way.
Thrust master 458 Italia racing wheel.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Have you tried the games settings first of all? steering linearity needs to be at 50?
My wheel is ok for 30 seconds then it uncontrollably turns right-%#*@ unusable and annoying it is, so ive got the top off and a lefthand side bit of plastic holding the main spindle/wheel coloumn has broken off and was rattling about in it so the wheel moves up and down more.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Hi Daniel, still got one?
I have replaced potentiometer.
Costed….. 0.5 USD, not exactly same but fits. Some tears, blood, sweat, assembled, adjusted, working like a charm. Original potentiometer in the centre of the wheel was a cheap, plastic, nothing has been left from the original circuit, caused that steering has became woobly, and not possible to drive exept in drift mode, finally stopped turning to the one direction.
If you got soldering skills and some tools for cutting plastic (knife can hardly fit) you can do it by yourselves.
10-12 kohm resistance and ability to turn in all directions without limits - this is prerequisite for potentiometer.
Mine got a block preventing turning more, opened it and removed piece of plastic that was a blocker.
Good luck.
Mateusz
Puan 0
1 Yorum:
Can you tell me what a potentiometer you mount? Any numbers? Part no.?
tarafından
Yorum Ekle
Here we have a replacement potentiometer for Thrustmaster gaming wheels that use the 'Bungee Cord System'
If you have steering faults such as constantly pulling to one side or not responding correctly then this part is for you.
Part Specs:
Number of Gangs: 1
Number of Turns:   1
Type:                      Rotary
Electric taper:         Linear
Shaft diameter:       5 mm  ,
Tolerance:               ±20%
Power Rating:         0.05W
Resistance:             10KOhm
Compatible with:
458 Spider
458 Italia
T80 RS
T80 488 GTB Edition
( https://www.ebay.co.uk/itm/324031263306 )
Puan 0
Yorum Ekle
Yanıtını ekle
Daniel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 23
Her zaman: 5,719
