I had this issue and found the answer from a friend of mine that ran several GM Dealer Service Depts in our region for many years.
Not saying you shouldn’t check for a parasitic draw. I did as well and found no indication of a parasitic draw.
What my friend told me is that there was a GM Service bulletin for my 2007 Tahoe (and other year and similar models) that you needed to change the Negative Battery cable. The bulletin indicates that the cables develop higher resistance over time and that keeps the battery from fully recharging. I thought this sounded odd, but if you really think about it, it makes absolute sense. Everyone (including me) thinks that if the alternator is producing enough Volts, that you’re golden. But nothing could be further from the truth.
The thing that keeps your battery charged isn’t Volts alone, but the Current, or Amps, that are able to flow to the battery. Too many Ohms, or Resistance, less Amps, or Current flows to the battery. Volts divided by ohms equals Amps.
Long story short, I replaced the Negative battery cable and problem solved. If you can’t find a parasitic draw and have tried other things, you might change the negative battery cable. But be ready if you do it yourself! Not fun….goid Luck!
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
0
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
2 Yorum
Hi,
Use a DMM's (Digital Multimeter) Voltmeter function to test if the battery is being charged at the correct rate.
Start the engine and connect the meter across the battery terminals. You should measure between 13.8V -14.2V DC to keep the battery correctly charged.
if it is not between these values check the alternator (or more correctly the regulator) which is in the alternator. If it is a "new" alternator take it back to where you got it from.
Be careful as the engine is running.
jayeff tarafından
Otherwise, take it to Sears or Autozone after a jump, and they can check your alternator for you for free.
S W tarafından
