Ana içeriğe geç
The third-generation HTC One smartphone which was first released in March 2015. Its major revisions on the M8 design include the octa-core Snapdragon 810 processor and a 20-megapixel rear camera.
71 Soru Tümünü görüntüle
Why is my phone randomly shutting down? (And other problems)
So I've had my HTC one m9 for about two years, (I got it used) and I've been experiencing lots of problems within the last year. When I first got it, it was working fine, but now it's really getting on my nerves. My main problem is that it shuts down seemingly at random times. Usually because of these factors:
Cold
Using camera
Below 40%
Not charging
When it shuts down, it (sometimes) wipes the app data and says that I have to update everything when my storage used stays the same. This happening several times results in my phone filling up with duplicate updates. But it doesn't wipe it every time.
It also has been consistently powering off below 40%, like I said, and when I put it on a charger, it says it's at anywhere from 5-20%.
Also sometimes when I power it on (not after a random shutdown) it will reset only my keyboard settings and quick settings.
I've tried wiping the cache partition and factory resetting it multiple times. Any help would be much appreciated.
Running Android marshmallow if that helps.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
The battery is probably not delivering enough voltage to the processor to keep the phone on. Just like how Apple was slowing down iPhones as the batteries aged, the processor needed more voltage than the battery could deliver. Best bet is to replace the battery.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Consider to change your battery. You have used your phone for 2 years now and looking at the problems I think battery is the culprit.
Puan 2
Yorum Ekle
Good answers, battery replacement is recommended first, after that if it's still no good then we may have a board issue causing this.
Puan 2
Yorum Ekle
I have the same problem I have purchased a new battery and still the same Don't think its a board issue
Someone told me its an app causing it  but did a factory reset without doing a back up and it still happens
Puan 0
1 Yorum:
Factory reset after replacement of battery
tarafından
Yorum Ekle
Yanıtını ekle
Colin Powers sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 6,656
