Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1505 Soru Tümünü görüntüle
Soru Kapandı
Ring/ Vibrate Switch function
My daughter's iphone had a busted digitizer and a cracked back so I decided to refurbish it with new glass/digitizer and rear case.
I used the excellent resources on this site and the disassembly was smooth.
Just a couple snags. Trying to re-install the Ring/Vibrate switch was a difficult in that it didn't want to stay in position while I was reinstalling the ribbon cable with the Switch. It would work once or twice and then would pop out of the switch. Finally it stayed in, but the switch itself no longer protrudes from the case, but is totally flush making it hard to use without a spudger. Is there a trick for getting the button in place and working properly?
Similarly the power switch protrudes about half what it did.
Any good tips?
jb
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Dizüstü Bilgisayar Bataryaları
An easy fix for a big power boost.
Hemen Alışveriş Yapın
1 Cevap
Filtre ölçütü:
I did this replacement also and on the power button at least I found out that the metal loop attached to the power button has to be down for it to work correctly. I put it up and it only stuck out about half as far.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 706
