1988 gmc 1500 transmission
I have a 1988 GMC 1500 the transmission just stopped working and I can't get it to go in low gear 4 wheel drive or anything what could possibly be the problem if it's not just a totally bad transmission.
Bu iyi bir soru mu?
Puan
Hi Robert, are you not able to get it into any gear, or just that you can't get it to go into 4WD-Low?
Jasen Friedle tarafından
Just a thought, you may not have the linkage attached to the transmission, if your trouble is you have no 4 wheel drive there is a clutch sort of electric solenoid that shifts the truck into any 4 wheel operation. You shove the handle to 4 x 4 and a electric switch energizes the 4 x 4 action, could be a fuse or the wiring snapped off or the coil is burnt.
altbell tarafından
@budrob "in low gear 4 wheel drive or anything" what is anything? What have you tried? Did this just start all of a sudden? Give us more information about your vehicle and what happened.
oldturkey03 tarafından
I have a similar but not exactly the same issue. The shifting worked perfectly until I got stuck in deep snow and rocked truck back and forth aggressively by shifting from 1st to reverse and back again. I also went in and out of 4 wheel drive- both high and low aggressively. The truck stopped moving after doing this a bunch of times. Fast forward 5 months - warm weather now - and I can get it to move forward and reverse in 4 wheel low and in 2 wheel drive. But, the performance is erratic and I need to almost floor accelerator. What can I do to fix it?
Dave Low tarafından
