Ana içeriğe geç
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Riding mower won't start
Hi, My Craftsman model 917.250, Kohler 26 horse won't start.
I hop on, depress brake, turn key, engine turns over.
It has good spark at spark plug - removed plug, reattached plug wire, turned engine over with end of plug held near metal frame, sparks.
Checked fuel, also squirted starter fluid in carburetor, turned engine over, still won't fire.
Squirted starter fluid directly in cylinder - removed plug, squirted fluid in cylinder, replaced plug, turned engine over, no fire.
Checked for damaged flywheel key, okay too.
Scratching my head, puzzled, any ideas?"
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
3 Yorum:
Scot Mckone if you have fuel and spark check your timing as well as your valves. You may not have compression
tarafından
My craftsman riding lawn mower will not start wont even click on what could be the problem
tarafından
My riding mower aslo wont fire done bought new plug new solenoid new fuse repaired wires also wont start only get a little click
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
try to bypass the ignition switch by puling it and closing the circuit manually
Bu yanıt yardımcı oldu mu?
Puan 0
5 Yorum:
If it is getting spark, how will over-riding ignition switch help?
tarafından
It may not, but I like to remove as many things from the system as possible when troubleshooting.
tarafından
The brake sensor may not be working too. It sound like you have been very thorough. Compression as mentioned by oldturkey may be your best bet.
tarafından
Has compression. how do you check timing?
tarafından
Scot, try using this previous thread as there seems to be a lot of similar issues...
Craftsman tractor engine compression or timing issue
tarafından
Yorum Ekle
Yanıtını ekle
Scot Mckone sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 7,284
