Ana içeriğe geç
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
Broken screen can't deactivate
I recently cracked the edge of my screen causing a few problems so I turned off screen lock and seems ok 90% of the time. Today's problem is I put battery saver on as was out and only had 5% and now I can't disable it as the screen times out straight away. To be able to get the phone screen back to working order I need to disable the saver back to normal. Help
Bu iyi bir soru mu?
Puan 4
2 Yorum
It fixed my problem as weel. I was unable to turn off the device and boot into recovery mode. Thanks for the post
tarafından
Hi my s7 edge has a broken screen cant see anything, and i accidentally turned on battery optimization pl3ase helo!?!?
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try this:-
You can force Galaxy S7 or S7 edge to power off without unlocking the phone by following these steps:
Step 1: Connect Galaxy S7 and S7 edge to wall charger with the USB cable and make sure it is charging.
Step 2: Press and hold Volume down button and Power button (holding two buttons) for about 7 seconds.
Step 3: Release power button, then volume down button.
Now, Galaxy S7 or S7 edge should be powered off. You can wake up the screen to verify. It should show a charging battery icon.
Bu yanıt yardımcı oldu mu?
Puan 22
11 Yorum:
I have spent hours trying to find a solution. This is the only one that works. Thank you very, very much. Now I can boot into TWRP and get all my files out.
tarafından
yes this is hard to find knowledge! On my broken note 5, this solution works too (just pressing down + power button only reboots phone, not power off). Samsung should have made it easier to force power off phone with sealed in battery
tarafından
100% working for my broken screen,Thanks
tarafından
This doesn't work for me. It's just causing the hard reset but the phone immediately powers back up. I need the phone to stay off so I can take out my sim card
tarafından
when i try this it just restarts my phone? HELP PLEASE.
tarafından
6 tane daha yorum göster
Yorum Ekle
My Galaxy 7 started repeatedly rebooting and the hard shut off did not work. I have a replacement phone but have files I need to get off the G7. Is there another way to cancel the automatic rebooting process that the phone is stuck in?
Puan 1
Yorum Ekle
It's really too bad that no one has a universal fix for this. What i ended up doing was taking the phone apart and removing the battery. What could be the problem is the button mechanisms are faulty from the damage as well.
Puan 0
Yorum Ekle
Thank you very much ... It did work
Puan 0
Yorum Ekle
Yanıtını ekle
Kel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 33
Her zaman: 67,110
