Screen replacement ambient light senor issues while making a call
Screen goes black and unable to wake until call has ended after screen replacement the auto brightness work perfectly thou
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Did this happen from no where or after drop / any part replaced?
have you cleaned the upper part of the screen? it is two diffrent sensors on same flex cable for the auto brightness and to shut down the screen when in a call.
if something is above that sensor or screen is replaced and its not enught light in to that sensor it will go black at once and stop when the call ends.
It can also be a defective sensor.
Heres how you replace it:
iPhone 6s Front-Facing Camera and Sensor Assembly Replacement
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 34
