Ana içeriğe geç
The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
Where to find wifi card on new 3ds xl?
Hi, my new 3ds xl has 2 black screens that never go on even though the power light goes on and stays on. I read that in older models it was often a result of an unseated wifi card. I've opened up my 3ds xl but I can't see the wifi card, it definitely doesn't look the same as the normal 3ds / 3dsxl so I am wondering where it is and if the unseating is still an issue in the new 3ds xl.
I found one other person asking for this on here, but their answer wasn't very clear so I'm stuck.
Can anyone please advise? Thank you!
Bu iyi bir soru mu?
Puan 6
2 Yorum
@hendrikgrobler search it up, they are pretty easy to find tbh
tarafından
@wyattd agreed !!!!!
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
According to the teardown on step 13, the WiFi chip is on the motherboard.
New Nintendo 3DS XL 2015 Motherboard Replacement
Nintendo 3DS XL 2015 Görseli
Kılavuz
New Nintendo 3DS XL 2015 Teardown
Zorluk:
Orta
Nintendo 3DS XL 2015 Motherboard Görseli
Kılavuz
Zorluk:
Orta
10 - 15 minutes
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I see, from the picture it doesn't look like it's something that can be unseated, it looks like it is fixed to the motherboard. Is that correct?
Thanks for your help!
tarafından
Yorum Ekle
It might not be the wifi card. If you have damaged ribbon cables underneath the left shoulder button, you may need repairs. I recently helped a friend with the same issue, and by messing around underneath the left button, I got the bottom screen to turn on. The top screen....I don't know. But if you get the bottom screen to work, I suggest not trying to do the same thing to get the top screen to work... *sweatdrop* (I ended up breaking it more after trying to get the top screen to work. I suggest being extremely careful. X'D)
Puan 1
2 Yorum:
I'll try take a look, thanks. It would be extremely helpful to know which components can be disconnected while still allowing the console to boot. Would make it a lot easier to diagnose which one is the problem. I've read about broken camera modules causing this kind of behavior as well as either screen.
tarafından
You're welcome. It seems that it was the wifi card and its good to know another reason why a ds wont work. (Honestly I wish I would've thought of that XD)
tarafından
Yorum Ekle
I know this is from 6 years ago, but here's what I did to fix my friend's N3DSXL with the same issue:
Firstly, I held: L trigger, R trigger, D-Pad down, and A.
I then turned it on (while still holding that button combo) to boot into safe mode, where the 3ds system can be repaired from a failed update, or to even just update the system.
After updating the system, this then brought me to a touch screen displaying "An error has occured" upon booting up the console. To fix this, take out the battery for a few minutes, then re-insert (discharging the battery is not necessary).
After doing these two things, the N3DSXL will have been fixed, and have booted to the home screen.
Hope this helps anyone in the future!
Puan 1
1 Yorum:
Hey there! Just saw this and had a question. How would I repair my 3ds (new xl) from a possibly failed update? The screen is not turning on though it does do this thing where it does turn on every once in a while. Not sure how it happened, just an issue I had a couple years ago and only now am I trying to fix it
tarafından
Yorum Ekle
I had this problem too. Even after taking the wifi chip or card off and back in, the problem would could back. Eventually I realized the wifi chip would get unseated since the foam that's supposed to hold it down was flattened, so I cut some more of similar foam down and put it inside. The issue has mostly gone away now, it only comes back every few weeks and I just have to press near the joystick where the wifi chip is located.
Puan 0
Yorum Ekle
Yanıtını ekle
Hendrik Grobler sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 36
Son 30 gün: 182
Her zaman: 16,660
