Gateway MS2300 won't power on
Hi guys.
so i have a Gateway MS2300 and it won't power on at all.
AC Adapter is OK
Capacitor Discharge by disconnect power sources and press and hold power key for long tested and nothing changed
i opened it and im going to check the voltage by multimeter.
we have voltage after charge socket.
we have 19v voltage on capacitors.
also have voltage on battery charge connector (1,2 GND) (3 4 5 are 3.2V) (6 GND) (7 8 are 19.2V)
power key (the micro switch) is ok (tested with buzzer test on multimeter)
what else i should check for this kind of problem?
thanks regard
Amir
Bu iyi bir soru mu?
@bakteriy any identifier (numbers etc.) on the motherboard? If so let us know what they are so we can determine what motherboard this is. That may help to find a schematic to help you out.
oldturkey03 tarafından
@oldturkey03 i will check this and update my post with serial number model number or anything else i can find.
thanks for your answer
Amir Hoseini tarafından
