Ana içeriğe geç
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
276 Soru Tümünü görüntüle
MacBook won't turn on - Logic board gets warm and seems to hold charge
Hi all,
I have a 2015 Macbook 12'' - just out of warranty (3 yrs).
I was browsing the Internet and all of a sudden everything froze (screen / mouse / keyboard). I held the power button down, it turned off; Since then, I have been unable to turn it back on.
Have tried SMC reset, PRAM reset, holding the power button in for 20 seconds (and various combinations of without/with power etc)...Nada. Keyboard backlight won't come on either.
The weird thing is that if I leave it plugged in, after about a minute, I can feel the underside of the logic board getting warm. If I let it charge then unplug it, the underside will remain hot for a few hours, just as if the system is 'stuck' doing something and draining the battery down.
Have opened it to try and disconnect the battery completely, in the hope that it is just stuck in some deep sleep mode and cutting all power would reset it...Nope. I can see the white LED on if I have charged it up, so parts of it seem to be working...
Anyone have any ideas?
Many thanks!
Update (02/25/2018)
This is what I see with the battery disconnected and the charger plugged in (you can see the white LED is on). The system will not start nevertheless...
The CPU? (big rectangle on the right) gets hot almost immediately...
Unfortunately it does look like an expensive repair :-(
Any ideas welcome!
Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
5 Yorum
Did you find anything out on this? My 2016 has the same symptoms and the little white light also illuminates.
tarafından
Did you get it to work?
tarafından
Unfortunately not….Had to replace the whole system board…Not cheap!
tarafından
Same problem, same observation of led and no solution, but does anyone have a idea of the cause?
tarafından
I’ll just leave this here.
https://youtu.be/y3zPKqrjrig
https://youtu.be/wbqwi24xEqc
I’ve replaced this chip on mine successfully (visually) but no luck. Don’t have as advanced equipment to test further.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The White LED on the front is to let you know your system is sleeping.
Lets try this open your system again and disconnect the battery and leave it disconnected. Resting it on its side plug in your MagSafe charger did the system spontaneously start up?
Let us know what happens
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Hi, this is a MacBook 12'' 2015 -
When I say the white led, I mean when I open it up, on the logic board, next to 'Battery disconnect' and the screw, there is a white led (which if I had it plugged in is on) and on the other side of the screw is a small button which if you keep pressed I assume disconnects the battery (led goes off).
Have isolated the battery by using the ifixit clip for a couple of hours, but that doesn't do anything.
System is using a USB-C charger, so I can't see the status led as you could with earlier Macs. Have tried using a new charger, but still same...
Thank you
tarafından
Sorry if I confused you I meant USB-C charger. Yes, the lack of an LED indicator on the charger or cable end does make this harder.
As the case is getting warm (battery) I'm thinking the charging logic on the logic board has a problem at this point. Time to visit Apple.
tarafından
Yorum Ekle
Yanıtını ekle
John Syrakis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 2,019
