Ana içeriğe geç
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
209 Soru Tümünü görüntüle
Dropped ipad mini 2. Screen looks fine. LCD needs replacing?
Do these kind of accidents usually only require LCD to be replaced? No cracks on the actual screen.
Bu iyi bir soru mu?
Puan 1
Yorumlar:
what does it look like? I don't know what you are describing. Adding images to an existing question
tarafından
that was fast.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Theres screen burns in the top left, so either way you probably need to get it fixed. the weird patterns on it, also probably the LCD.
iPad Mini 2 Wi-Fi LCD Replacement
Bu yanıt yardımcı oldu mu?
Puan 3
Yorumlar:
Most definitely a damaged LCD, it has to be replaced. The top left is not screen burn though, it's cracked LCD and that is the liquid part of LCD leaking into the surrounding area. Because it is no longer in cells (pixels), it cannot be controlled and is therefore opaque.
tarafından
@captainsnowball @refectio Thanks for the info! I will be opening it up tonight. Would the liquid happen to damage anything else? I have a replacement LCD and adhesive strips. Hoping this is all I need for the fix!
tarafından
Liquid? you didn't say. yes it will most likely. you need to completely disassemble the device iPad Mini 2 Wi-Fi Logic Board Replacement (this guide almost is complete dissassembly) and clean it in alcohol. Electronics Water Damage
tarafından
@captainsnowball not liquid damage but liquid from the damaged Liquid Crystal Display (LCD)!!!! ;-)
@mattmart89 you'll be fine with replacing the LCD according to the guide. No worries about the liquid, it will not go anywhere else.
tarafından
@oldturkey03 Thank you for the info! LCD replacement did the trick!
tarafından
Yorum Ekle
if you are able to take the screen off with out damaging it you can get away with only replacing the lcd
Puan 0
Yorum Ekle
Yanıtını ekle
MattMart89 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 43
Her zaman: 1,794
