Ana içeriğe geç
Screen won't work after replacement
I replaced my screen on my iPhone 6 plus a while back, and I tried to replace a broken camera on it today. I realized before trying to remove the camera that I had bought the wrong part, but when I reconnected the screen it lit up, but stayed black. I did in fact forget to disconnect the battery when I replaced the screen. I tested it using the old screen, which worked at first, but stopped working after testing it a second time. Is there anything that can be done to fix this?
Bu iyi bir soru mu?
Puan 0
1 Yorum
There's no image that shows up with the screen, just the backlight turned on
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Just backlight, confirm the phone boots up by plugging it into computer and opening up iTunes or 3utools it should detect it there.
If it does, then the screen has just gone bad, has backlight but no image.
You already tried unplugging battery and reseating the cables right?
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
The phone does boot up, iTunes recognized it and it will be late when on, but I've unplugged the batteries and reseated the cables both. It is in fact just backlight though, and the screen has worked for months before today, the problem only started after taking the screen out.
tarafından
Yeah you will need to replace the screen to fix this issue.
tarafından
Yorum Ekle
You're sure the cables are connected 100%, this can sometimes happen when they're loose
Puan 0
1 Yorum:
Yes, I've unconnected and reconnected the cables multiple times, both with my old screen and the one I've been using
tarafından
Yorum Ekle
Yanıtını ekle
Lucas McIntire sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 18
Her zaman: 118
