Laptop won't turn on!
My laptop won’t turn on even while plugged in and I’m not sure why..any ideas?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hello Karen! If the laptop shows no signs of powering up when plugged in, there may be a problem with the power adapter or the battery. If it is the power adapter, then plugging in a compatible charger will help the laptop power up. If it is the battery, then a new charger won't work and you should look into getting a new battery pack for your laptop.
Bu yanıt yardımcı oldu mu?
if the power adapter is ok the laptop should still work whether the battery pack is good or bad no?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 1,466
