Using Suction Cup to remove screen with a screen protector
Can you still use the suction cup to lift up the screen if you have a glass screen protector (ZAGG) installed on the screen or will it lift off the protector?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You can use suction cups no problem but on cracked screens the glass tends to separate from the palstic frame if it is an after market screen.
I always use razor blade on sides of screen to lift it up after taking out the two pentalobe screws.
Bu yanıt yardımcı oldu mu?
Brian, you can use a suction cup to remove the screen. The screen protector won't come off
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 2,362
1 Yorum
Thanks for the answer. Worked like a charm. Battery replaced in about 20 minutes
Brian Thompson tarafından
