Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
543 Soru Tümünü görüntüle
MacBook Pro shows no signs of power
I have a 15" Macbook Pro retina that wont turn on. Charging light is green, only when I unplug the battery the charging light will turn orange, but either way the unit does nothing when I press the power button, no fans no sound no power. Any ideas out there what this problem may be? Tried SMC and PRAM resets
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
There are many things that would cause this problem. Normally the charging light should be green without the battery plugged in or the battery is full. If the light color as you said, this could be the power module (where the charging cable connects to the laptop).
Has any liquid been spilled on the keyboard, or has any liquid got into the laptop? If any liquid spilled on the keyboard it would damage the keyboard so that the switch can’t connect the power to start the laptop.
You can try to disconnect the keyboard and reconnect it. If the logic board failed I am afraid that there is nothing you can do apart from replacing it.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Amber Savoy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 95
