Ana içeriğe geç
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
210 Soru Tümünü görüntüle
lcd comes on but no touch works
replaced the lcd and glass, customer brought it back with ghost touching and also after time the ipad wouldnt react when touching the screen. placed kapton tape on the glass and still the same issue. i have tried sliding the screen by just touching the lcd but no luck, does it need a new lcd? or will the lcd not react anyways when touching?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorumlar:
the touch only works if you touch the glass. The LCD is just that, an LCD to view images.
As the companion says, the problem is in the tactile crystal. Sometime I happen that after changing the screen, the touch stops working a while later. Phantom touch seconds the motion, bad touch screen.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This sounds like more of an issue with the digitizer glass/assembly. I'd recommend looking into reseating the cables for the digitizer and making sure no debris are in between the digitizer and the LCD. If not, you might need to look into a new digitizer. Good luck!
iPad mini 1/2 Screen Digitizer Görseli
Ürün
$44.99
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Nathan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 121
