Ana içeriğe geç
THINKPAD T520: Top Tier Performance and Portability.
Can't Access BIOS Settings using F2/F1. Operating System not found.
I turned on my laptop, boot settings appeared, pressed the F Keys BIOS not appearing than next thing Operating System Not Found. Please Advise me what to do and how to go about fixing it!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Hi joshua , try connecting a usb keyboard and access the BIOS,
Hit F1 to access the BIOS Menu / or Enter (List of Menu)
tarafından
Tried that didn't work.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Normally, you would press the enter key when the Lenovo splash screen displays, and choose options after that. The power manager may need to be reset, hold the power button and hold for 10 seconds after the laptop turns off. There may be a small hole in the bottom case that will reset the power manager, use a small paper clip to poke through the hole and press for 10 seconds. You should run diagnostics to see if BIOS recognizes the drive.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
joshua fiu sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 3,028
