Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
250 Soru Tümünü görüntüle
Ipad Mini unresponsive in every way
hi
my sons ipad min was dropped and the screen cracked. It was left for a while as we went on holiday. Came back and tried to charge it up but it wouldnt charge and its not recognised in itunes either. Ive tried a hard reset whilst its plugged into itunes but nothing.
Any help appreciated
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
Update:
I dismantled iPad to expose the battery (the LCD wasn’t cracked) I peeled the tape away at the bottom of the battery to expose the batter + and - terminals. I set my multimeter to DC and tested across the terminals. The reading was zero. I then plugged my charger in and tested whilst on charge and still zero.
So could be the charging chip??
tarafından
Yorum Ekle
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
If the screen cracked after the drop, then it probably took some heavy damage internally. I presume you meant the front glass is cracked but it is also possible that the inner LCD is also damaged. As for the device not starting, it could also be caused by the battery connector becoming partially disconnected.
At any rate, the only way to understand the problem will be to open up the device and start troubleshooting. I would take a look at this guide to see if you are comfortable opening the device. The iPad mini is one of the more difficult iDevices to repair so you'll need to be honest with yourself about your abilities.
I would start by inspecting the LCD to see if it is cracked. If not, then check the battery and digitizer/lcd connections to insure they were properly seated. then you could measure the voltage directly at the battery. ~3V should be sufficient to allow the device to boot. So if the battery has more voltage than that, your problem may be within the logic board.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorumlar:
Thanks for your answer. I will try what you suggest and post the results back
tarafından
Good luck!
tarafından
do i measure the voltage on the battery after its been charged for a few hours?
tarafından
Sure, you can measure it before the charge and then after to see if it has an effect on the boot.
tarafından
Update:
tarafından
5 tane daha yorum göster
Yorum Ekle
Try to left it to charge for at least 2 hours.
then try to boot it in DFU mode, in itunes.
If nothing happens and stay undetected, then might have logic board issues
Puan 0
Yorumlar:
Thanks for your help. Tried that but still nothing
tarafından
then may have battery or logiboard issues....
tarafından
Yorum Ekle
Yanıtını ekle
ian sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 108
