Ana içeriğe geç
Pontiac Grand Am, Pontiac tarafından üretilen orta boy (ve sonraları kompakt) bir otomobildir. 1999-2005 nesli, Pontiac Grand Am'in son neslidir.
Crank but don't start
I have a 2004 Pontiac Grand AM that cranks but does not start. We have replaced the fuel filter, fuel pump, fuel regulator, and fuel pump switch but it still does not start. Can you send me any more advise????????
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
3 Yorum:
Please help ???????
tarafından
After everything I had told you I was going to replace the crankshaft angle sensor and disconnected the negative on the battery after some delays I connected the battery back up and just out of curiosity tried to start the car and of all things the car started. Can you give me a opinion on why the car started.
tarafından
That worked for me! Just disconnected the negative on the battery for a little while and reconnected it. Thanks! 2005 Grand Am
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Get your car scanned for codes first off. Always do that before replacing anything.
I'd bet though it is probably your crank angle sensor, but get it scanned first.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
u must check engines before start ur car thats very imporant ur car before on road grab some sensor battery and check on battery on your car maybe is low or high and also dont forget about the oli its may low oil if oil is empty the car won’t started
Puan 0
Yorum Ekle
We are having exact same problem. Only code is O2 sensor, replaced both, still won't start code still says O2 sensor
Puan 0
Yorum Ekle
Yanıtını ekle
Jimmy Samora sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 5,605
