Both fans running high constantly from cold boot up
Hello all
Picked up a clean , late 2008 mbp 15.4" , 2.4ghz intel core duo, 4gb ram, 250gb sata drive,
The problem is both fans are roaring away at full speed the second I press the power button.
I removed the battery, reset the smc. Reset the nvram / pram. Still the same!
Now then, I removed the rear case, hoovered out all the dust and fluff. Gave it a good inspection. Repasted the 3 chips, reseated the heat sink and reassembed.
The laptop then , wouldn't boot unless i held down the power button and plugged in the magsafe (battery removed). The laptop wouldn't boot with just the battery on its own either. And wouldn't boot if the magsafe was connected before the power button pressed.
When it finally booted up, fans roaring away again.
The same happened in safe mode also.
I installed El capitan. Then installed Yosemite. Then went back to Snow Leopard. All the same on all 3 osx versions , fans running high.
I installed TG Pro fan software , tried smc fan control and mac fan control software. All fan software resulted in 'no fans detected on this machine' , therefore no control option to lower fan speeds.
I removed the original 250gb apple sata and tried a ssd in place and it booted from the power key alone. Put the original sata back in and no boot unless, power key held down then magsafe plugged in.
Has anyone any ideas what it could be ? Why are the fans running at take off speed the second laptop powers on? Why are the fans not detected on machine by software? Why a change in hard drive type allows machine to boot off the power key and then not?
Theres no liquid damage or any other signs of anything to suggest otherwise. The machine has never been dissassembled before. The superdrive dvd player doesnt accept discs either. The original battery charges up but wil need replacing at some point.
Thanks for readng
Bu iyi bir soru mu?
1 Yorum
It seems that might be not detecting something correctly. Check your ram and your temperature sensors too. Boot with as less parts required to boot.
ssavva05 tarafından
