Battery issues? Can someone help me
Conectado a red, funciona, pero no recarga bateria . Dice siempre 60% de carga y no parpadea el led. Le quito la bateria y sigue funcionando a red y si parpadea el led.
Le pongo bateria nueva, y funciona conectado a red, pero no carga y no parpadea el led. ????
Connected to the network, it works, but does not recharge the battery. It always says 60% charge and the led does not flash. I remove the battery and it continues to operate network and if the LED flashes.
I put new battery, and it works connected to the network, but it does not charge and the LED does not flash. ????
Bu iyi bir soru mu?
¿Has probado con otro cable?
Rachel Acosta tarafından
