Ana içeriğe geç
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
Wifi doesn't seem to be working. Is this fixable?
Every time I try to connect to wifi it tells me the signal is too weak. I've tried plugging it in to the PS3/PS4 and the router and no luck. Any ideas? Is there a way to replace the wireless card/broadband adapter?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi!
While there is no user replaceable WiFi-Card, you could try reseating the antenna connector. Follow this guide until step 11 and unplug the cable that's marked with purple in the guide. If that does not work either get closer to the router or replace the main board. Note that even if you plug the PSP into a PS3/ PS4/ router via USB the internet connection won't be shared.
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
Note that the PSP 2000 is an 802.11b only card. You will have to double check that the Wi-Fi on your router is set to allow ancient 802.11b.
tarafından
@avanteguarde Yeah, right, I forgot about that. Most routers do support that old standard tough
tarafından
@alexniculescu I agree it is supported, but it is disabled. The reason being is WPA2, especially WPA2-AES does not work with 802.11b.
tarafından
I was also wondering about the 802.11b. That would probably make a difference as well. Thanks for the help guys.
tarafından
Yorum Ekle
It will always say signal too weak. There is nothing wrong with the WiFi card, but the communication protocol is outdated and no longer supported, hence the said error.
Just buy an old router that is still compatible and bridge to your network.
Puan 1
Yorum Ekle
https://youtu.be/a4qjcvZ6xFE
Puan 0
Yorum Ekle
Yanıtını ekle
jbrady2 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 42
Her zaman: 2,271
