Ana içeriğe geç
You know them, you need them, they move your cursor around. Repair information for your nest of mice.
479 Soru Tümünü görüntüle
What is the best way to oil a mouse scroll wheel?
I have a mouse with a bit of a scroll wheel issue, as it will squeak every now and then, and is a little sluggish. What would be the best way to oil it? Would WD-40 work?
Thanks in advance!
Bu iyi bir soru mu?
Puan 0
1 Yorum
Had a Razer Deathadder squeaky mouse wheel. I used a little molybdenum graphite powder. Worked like a charm.
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
WD-40 would not be a good idea. It is probably lint and fibers collecting on the wheel's axel. Most mice are easy to disassemble, there may be covers over the screws on the bottom of the mouse. Once the axel is clean then it should be able to move in its sockets without any need for oil.
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
You think that could cause the squeaking as well?
tarafından
I would say so.
tarafından
I know this is pretty old but I'm dealing with this problem now and I've already cleaned the whole mouse. I disassembled it, took the motherboard out of it, and isolated the mousewheel to clean it better. I cleaned it using 99% pure alcohol and let it dry for hours. Now my mouse has 0 particles of dirt/whatever and 0 cat hairs in it.
However, the mouse wheel seems to be as hard as before, if not harder. Before cleaning it with alcohol, I noticed the wheel itself had a layer of some oily substance, so I think I DO need to re-lube it. What can I lube it with?
tarafından
Yorum Ekle
Usually and very small "dab" of 3 in 1 oil with a Q-tip will do.
Puan 1
1 Yorum:
When you say oil, what do you mean by that? (I know this question is old, but the issue persists)
tarafından
Yorum Ekle
It’s a 3 in 1 silicone based lube at Home Depot it comes in a tiny bottle
Puan 1
Yorum Ekle
The scroll wheel on my brand new HP X500 mouse squeaks consistently. Can't be dirty. I have food grade silicone, graphite powder, Fluid Film (recommended by Medeco), and 3-in-1 oil. Now to chose...
Puan 0
Yorum Ekle
Yanıtını ekle
Reed Crosby sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 33
Son 30 gün: 229
Her zaman: 30,478
