Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Repair guides and support for the first generation Town Car, a full-size luxury sedan manufactured by Lincoln.
11 Soru Tümünü görüntüle
My Brakes Don't Give Resistance
My brakes are fine and I just replaced the lines, but the pedal itself doesn't give any resistance. I get it down to the floor before I actually stop. How do I correct this?
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Were the brake lines bled properly after installation? Even a small air bubble in one line will make brake pedal feel spongy.
https://lincolnforums.com/forums/#
The above forum may help too.
Best o' luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorumlar:
Yes, the mechanic who sold it did the bleeding
tarafından
I'm not sure why, but that reads funny.
tarafından
Yea, it kinda does. I'm gonna try bleeding them again and see if that helps
tarafından
Well, it's been a while...did you ever get the brakes working proper? Just curious.
tarafından
When you say lines, what do you mean?
brake hoses?
if so why did you replace them?
tarafından
1 tane daha yorum göster
Yorum Ekle
Sounds like your issue is the portioning valve. This valve pushes the correct amount of brake fluid to the brakes, and is what gives your pedal pressure. Had this same issue with my 1999 Ford Taurus, would push the pedal to the floor before any minimal response. I hope this gives some insight to your issue, as I'm no car genius. Good Luck.
Puan 0
Yorumlar:
Do you know any way to correct it?
tarafından
If the valve is bad, it can be a very expensive replacement
tarafından
Yorum Ekle
Yanıtını ekle
Bradley Edwards sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 78
