Ana içeriğe geç
1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
162 Soru Tümünü görüntüle
Battery has swolllen, can see the damage on the device
Good day,
The battery has swollen in the MacBook Air 11" the damage can be seen on the device. my question is if I order the replacement battery fix kit, do I receive all the necessary equipment to open the device e.g T5 screw bit?
Will there be other damages?
Thank you
Kind regards.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You should receive everything you need to perform the repair in the kit. Other damages to the device could potentially be to the trackpad, case, and -if it's bad enough- the keyboard. I'd really recommend replacing the battery first before you try looking into other damages as just replacing it may be enough. I've seen MacBook batteries so swollen they are literally crackling and moving after being taken out and the device was fine after the replacement. Just be careful!! :)
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thank you.
Kind regards.
tarafından
Yorum Ekle
Yanıtını ekle
Stefan Coertzen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 57
