Popped off the battery connection from the logic board... fix?
I wanted to accesses the other side of the logic board because of water damage. I took my spudger and popped the little connector that the wires from batter slide into. This connector is located on the top of the logic board middle, closest to the battery, its the set of wires with a water damage indicator on them right in the middle, hard to miss (if that helps). the wires from battery slide into this connector that I popped off the logic board. Its one of the first steps when wanting to take the logic board out. I believe its the main power supply to the logic board. Is there a way to glue the connector back on (with high temp. adhesive ) or another fix ?
Bu iyi bir soru mu?
1 Yorum
It is possible to repair this. Microsolderers can work with REALLY tiny stuff---we would solder wires to the torn nubs of the traces and then solder a new connector, and then connect the wires back to the connector.
jessabethany tarafından
