iMac screen discolored (smudgy)
Hi,
I bought a used 2007 mod. iMac 24" 2.8Ghz. Now I wonder if there is something wrong with the screen. When I start it up I see areas with yellowish discolored areas and I can see icons and some text shining through at the bottom of the screen, but not icons from the dock. When it is up and running, if I change the background to white I can see the discolored areas more clearly. I have an older 20" white iMac Intel and it does not have the discolored areas. Is this normal and is there a way I can fix this without having to replace the LCD?
Here is a link to a couple of pictures:
Can you post a picture of this?
by rab777hp
Could it be burn in? I've never seen that on an LCD but it sure sounds like it. Ralph
by rj713
It'd be pretty hard to get a burn like that on an LCD as you say. If it is a burn, must also be some problem with the inverter or something, that thing shouldn't be getting that much juice!
by rab777hp
Looking at the pictures I would say that's definitely not burn in. Ralph
by rj713
But is it normal? And if not is there anything to do about it? My white iMac 20" is not like this.
by asle
Show 2 more comments
