Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2265 Soru Tümünü görüntüle
Why isn't my touch screen working after screen replacement?
I cracked my phone a couple weeks ago and got the screen replaced. Since then, I've been having trouble with my touch screen. It won't always register my touch, and sometimes it will move/type/click on something without me touching the screen. Before getting the screen replaced, even after the phone cracked, the touch screen worked perfectly. What could this be, and how can it be fixed?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Did you make sure all ribbons and connectors were firmly in place when you replaced the screen? One possibility could be a loose cable. What you can try doing first is performing a restart a couple of times to see if it calibrates properly. Press and hold down the home button and power button simultaneously until the apple logo appears, then let go. Do this a few times, maybe 3, and see if it helps. If that doesn't help, then another possibility could be that the screen is faulty. If so, have it replaced.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Maybe some screws was mixed and install wrong lead to this issue.
Puan 0
Yorum Ekle
Also this issue was present on iOS 11.3 when using an aftermarket LCD. You can try updating to 11.3.1. Sometimes it can fix this issue.
Puan 0
Yorum Ekle
Yanıtını ekle
Bailey Smith sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 118
