Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1098 Soru Tümünü görüntüle
Ear Speaker and Front Camera working on and off
I have an iPhone 7 plus that I recently repaired that the ear speaker works randomly and the front camera is very slow at coming up and/or sometimes doesn't work in apps such as snapchat. This iPhone has been fixed previously and has been working fine.
Now I've replaced the front camera and speaker with a known working original with the same results. I also uncovered another issue. The phone will get stuck on the Apple logo after rebooting and will only boot normally after I do a hard reset. I tried different batteries and a different front camera flex with the same result. At this point Im scared to update to 11.3.1 or even restore it, because I'm afraid it wont boot properly and brick the phone
Any words of wisdom before the customer makes an insurance claim? Is this maybe a software issue and not a hardware issue?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The iPhone 7 series of devices suffers from issues with the Baseband IC, Audio IC and weak traces on the pcb which crack and break. It is a similar design flaw to the iPhone 6 Plus, known as Touch Disease. On the iPhone 7 series, the weak traces are underneath the Audio IC.
In many cases an internal short within the Baseband IC causes the boot looping, which unfortunately, is not repairable because the Baseband is code locked to the logic board. It can also be caused by a broken trace underneath the Audio IC. Replacing the Audio IC and strengthening the weak trace with a micro-jumper can repair this.
If you are curious about the technical nature of these failures, you can listen to this video from Jessa and this one from Jason at STS, they go into a lot of detail regarding this issue. It could be BB or Audio but the info in the video should help you figure out which one.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorumlar:
Thanks for the info. I will definitely look into this further. Is this something that could have been caused by me? Im extremely careful with removing the flex. The customer did admit to getting some water in the area where the flex connects although there is no visible water damage.
tarafından
I doubt you (an experienced tech) damaged multiple flexes...
tarafından
Im going to close this and accept your answer. The videos you linked are the exact symptoms Im having. Thanks again.
tarafından
Great! Good luck on the fix.
tarafından
Yorum Ekle
Yanıtını ekle
Brian Wood sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 276
