Ana içeriğe geç
PlayStation 3 (veya daha sık bilinen adıyla PS3), Sony Computer Entertainment tarafından üretilen üçüncü ev bilgisayar eğlence sistemidir ve PlayStation 2'nin akabinde devamı olarak üretilmiştir. 11 Kasım 2006'da piyasaya sürüldü.
781 Soru Tümünü görüntüle
How to see if the laser works?
how can i see if the bluray laser is working?
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You do not want to look at the laser it can do permanent damage to your eyes. The answer is rather obvious, though not the answer you are looking for. If you put a disk in and the disk spins and it reads disk(s) it is working. If it is spinning disks but not reading them then I would try cleaning the lens with isopropyl alcohol to do that you will need to disassemble the PS3 to get to it. There is a link to a guide below that will show you how to get to the laser. If cleaning it doesn't work the laser assembly needs replaced. You can find replacements here or on eBay. Instructions for replacing it are here. Please look at the tool requirements in the repair guide before you begin. You will also need to purchase the correct laser assembly, all pS3s do not use the same one. You will need to get the part number off the assembly.
Bu yanıt yardımcı oldu mu?
Puan 7
19 Yorum:
well i have a brand new one, from ebay.
and it sems to pull the dvd do far, it will not get centerd:S
i can put upp a movie in a few min
tarafından
+ Thank you for the videos! They have helped. The disk is not spinning. Did you just replace the laser on this or did it just start doing it?
tarafından
Yes it just hapend so I thong it was the laser, because it happen to my friend, and I swap it and it it workt....
But now it don't so I think maybe the "new" laser I broken too or something els
tarafından
You installed a new laser assembly. Did you remember to remove the clip from your old laser and screw it on the new? If you didn't that is more than likely your problem. If you did, for the moment lets just say that the laser is good. If it is good then there are 2 causes of your new drive not spinning discs....1) Things aren't lined up properly. 2) One of your cables isn't plugged in properly. Go back reseat all your wires, make sure they are in their sockets snug and square to the connectors. Then give it a try. If that doesn't work tear it down again including removing the laser assembly and reinstall everything double checking wire connections etc... make sure that the track the laser rides on is square, installed correctly and that the laser assembly is seated properly on it's starting spot. There is a good guide with pictures here: http://forum.blu-ray.com/blu-ray-games-p...
tarafından
14 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
DANIEL bernesdsd sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 36
Her zaman: 44,855
