Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
1883 Soru Tümünü görüntüle
Shorted baseband > New baseband reprogram
Hey people i got this iphone 7 for data recovery. i found out that the baseband is shorted. So i took of the baseband and now the short is gone. i want to buy the 1000s pro and a baseband module to reprogram a new baseband. But i,m not sure how they do it. below i got a link to the product:
https://www.aliexpress.com/item/PHONEFIX...
Here a link of the video:
https://www.youtube.com/watch?v=lH9r55n_...
My question is: how does the machine read the baseband serial. do you take of the baseband first and then put the motherboard in the machine and the machine reads the pins on the motherboard? or ? i cant find anything on the internet and nobody can help me. i hope someone knows more about this.
Greetings,
Thies Baarsma
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
The Essential Toolkit
The most helpful tools in our most compact kit.
Hemen Alışveriş Yapın
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
This machine only programs the Baseband EEPROM, not the Baseband IC itself. If you have a shorted BB CPU, then there's nothing you can do to repair/reprogram it.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorumlar:
Not any more! It was recently discovered (credit to Jessa Jones video), that to get the data off, you can boot the phone with a doaner baseband CPU that is working. No, phone calls will not work and im not sure if restoring will work - but you can boot and get a path to data! :) Best of luck!
tarafından
Hey @joesipaq, thanks for the update. That doesn't change the answer to the OP's question though, they were asking if the BB can be programmed in order to repair the phone...it still can't :(.
tarafından
True, it isn't a solution to make the phone 100% but I saw the "Hey people i got this iphone 7 for data recovery." And kinda assumed that was the main goal of his post that was leading into the other questions about programming the bb. I thought it would be some valuable information for his situation to get data off :) I wish we could program the baseband... That would be great -_-
tarafından
Joseph- where can I take my iPhone for repair where the person has the skill to "boot the phone with a doaner baseband" in order to extract the data? My phone stopped working in the middle of an update and now shows error 47, which I believe relates to a baseband issue. At this point, we just want the data off the phone since it had been quite a while since the last back up. We are hopeful this is a potential fix, but I am not savvy enough to pull off such a repair. I live in NorCal near Sacramento. Any suggestions who could repair?
tarafından
@iphone7problem look locally for a reputable shop that does micro-soldering repairs. Ideally, you want to find someone local but good workmanship trumps locality. There are many shops worldwide that do this so you shouldn't have any problems finding them. Talk to them and ask how they do their work. Be wary of those who say "no problem" without much else.
If you can't find one locally, then consider mail-in repair. There are several reputable micro-solderers patrolling this forum.
tarafından
Yorum Ekle
it looks like they keep the baseband ic on the board
Puan 0
Yorum Ekle
BBCPU can`t be reprogrammed that is unique by one.You can only reprogram BBEEPROM. If BBCPU was reprogram able 100% iPhone 7 & 7Plus on functioning till days.
Puan 0
Yorum Ekle
anyone can explain , what are the proceedures and what tools we neeed when changing BB CPU for iphone 6 , 6 plus , and aslo from where we get data to write pcb
Puan 0
Yorumlar:
You can’t change bb cpu it’s paired to the logic board.
tarafından
thank you for your replay , yes i know , but why poeple selling new BB CPU in gsm market , actally i have NEW BB cpu for iphone 6 , but i dont know how it work and what the benefit of it, so i guess there has some machine to programm ing to pair and match with new bb cpu
tarafından
Yorum Ekle
Yanıtını ekle
thieske sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 30
Son 30 gün: 85
Her zaman: 4,103
