Unit records only a couple minutes, then says card full
Records only a couple minutes, with a brand new card, then says card full.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi @smokn6string ,
Has it worked OK before using the same capacity card as you are trying to use now?
Has it got the latest firmware installed?
Bu yanıt yardımcı oldu mu?
I believe this SD card was ONCE formatted by a different unit than the Video Camera. IF you have a SD card formatted , let say by your computer, even you format it again with the video camera, this card will NOT work on the video camera. It will work for half a minute and indicated NO SPACE, card full. That means the SD card cannot be formatted by anything BESIDES the video camera
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 204
