Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
The Nokia N8 is the first device to run on the Symbian^3 mobile operating system and Nokia's flagship device of 2010.
55 Soru Tümünü görüntüle
Soru Kapandı
Any easy way to repair constant "insert sim" restart?
My N8 has recently starting constantly rebooting due to an "insert sim" message. It seems like there's something wrong with the sim card. It's been working great for 6 months but this started recently.
The tear down shows the sim card slot has 6 pins that could be pulled up with a pick through the holes.
Are the screws re-useable? The service manual says no.
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
My N8 phone insert to sim and phone will off what to do now?
tarafından
Yorum Ekle
10 Cevap
Filtre ölçütü:
Hello!
SIM cards can fail sometimes, even after short life (it happened to me).
Before gutting the phone, I think you should diagnose a bit : test it with a SIM card that's known to work.
Ask a friend/relative/colleague to borrow you theirs so you can test it in your phone to make sure wether the problem is the SIM card or the device.
Good luck!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Try cleaning the simcard's chip area and the pins of sim card reader...
sometimes moisture causes this type of problem
Puan 0
Yorum Ekle
Asslam-o-Alikum
brother i have Nokia N8 and the problem of this phone is this (insert sim card and restart phone) anyone who know the solution? thanks in advance
Puan 0
Yorum Ekle
From my experience, the six gold spring loaded connectors in the N8 SIM socket can easily be damaged or broken when inserting incorrect SIM such as micro Sim in an adapter. (Refer page 10 of N8 user guide) An expensive fix is to send to Nokia centre for around $100 USD. Or if you are experienced in dismantling Nokia phones, the SIM socket can be replaced, or the broken pin reattached by soldering. Not a job for the inexperienced.
Puan 0
Yorum Ekle
I fixed it by passing a pencil eraser on the contacts of the sim card. It's one of the best ways to clean golden contacts.
Puan 0
Yorum Ekle
Hi! I have the same problem! my SIM CARD SLOT is broken, and I already have the new part to replace it, but Im not sure wich is the best way to unweld the broken slot and weld the new slot. Somebody can help me with a video tutorial???
thanks a lot
Puan 0
Yorum Ekle
just chang mic
100% solution
tested by me
Puan 0
Yorum Ekle
hi any one help me my insert sim card restart my nokia n8 plz?
Puan 0
Yorum Ekle
my nokia n8 restart after insert sim card this softwear problem? plz help me
Puan 0
Yorum Ekle
i have nokia 500, when i start my phone with SIM in it , then it restarts, but if i start my phn with no SIM then it works fine, i checked it with other SIM, i did hard reset, i even reinstalled the software using nokia suite but the problem still persists.. please hlp .
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 25,556
