Ana içeriğe geç
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 Soru Tümünü görüntüle
MacBook will not power up
My laptop (MacBook pro 15 inch late 2011 edition) won’t power up anymore; resetting SMC, trying other adapter, etc doesn’t work. The light on the adaptor is green, not orange, so it’s not charging. When I press the battery indicator button on the side of the laptop when the adaptor is not connected, the battery seems completely drained.
I think the battery is defective - but I find it strange that the computer won’t turn on with the adaptor connected. Before I order a new battery and change it I wonder if a faulty battery is really the cause. Any thoughts? Suggestions highly appreciated!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Disconnect the battery from the logic board and plug in magsafe..the board should start by itself, no need to press power button. If it starts then it's probably a battery issue, if not something is faulty on the logic board side.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Thank you. I opened the MacBook and disconnected the cable between battery and motherboard (can't get the battery out because I lack a Y1 screwdriver, but I think disconnecting the cable should be enough) and unfortunately the laptop didn't start when plugging in the adaptor. So, I guess not a battery issue. Thanks for your advice.
tarafından
Unfortunately yes, that proves it's not a battery issue. Any further testing would need more advanced technical skills since it's likely a component repair is needed or a logic board replacement.
tarafından
Yorum Ekle
Yanıtını ekle
Marc Engelen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 76
