Memory Upgrade from 1066 Mhz to 1333Mhz
Hi,
I was wondering what happens if I install SODIMM DD3 1333Mhz memory instead of 1066 Mhz on my Mac Mini 4.1 (A1347).
Thanks in advance.
Bu iyi bir soru mu?
Hi,
Thanks in advance.
Bu iyi bir soru mu?
It may run and it may not. The bus speed is 1066 MHz so that's your bottleneck. Over the years I've found that boards are rated at a certain minimum but may actually run faster. Two identical machines and one may run 10-20% faster
Won't work link:
http://www.moeding.net/archives/25-Faste...
Will but mostly won't:
http://forums.macrumors.com/showthread.p...
You'll do much better using "matched memory": http://www.everymac.com/systems/apple/ma...
Bu yanıt yardımcı oldu mu?
i have installed recently 2 sticks of Kingstn memory running at 1333Mhz and 4gb x 2 (not paired) and it rocks! it seems that if the bus speed is 1066 and the ram is 1333 it will work. But remember to reset the pram after the ram switch....command-alt-p-r................
Even though it worked, did you run any benchmark tests on both sets of RAM?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 7,709
