Ana içeriğe geç
iMac dv won't complete startup
After attempting to install updates i believe 10.2.4, it required a reboot but system just gets to the Apple logo screen and the timer wheel keeps spinning. I have left it in this state for hours never completes. I have tried all sorts of key start-up combinations: s, command-s, shift, cmd+shift+del+opt, v, spacebar, cmd+opt+o+f. never gets past apple logo.
i don't have OS disks. any ideas would be welcome.
thanks in advance.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If OSX is installed, restart the iMac while holding down Command S. When the text page appears,
Type: fsck -fy then press RETURN key (NB: there's a space between k and -).
You'll have to wait a little while the installed OS is scanned and repaired. When the repair is done you should read "The volume <<hard drive name >> appears to be OK" If you see "File system has been modified" retry the procedure (fsck -fy) until you see "The volume <<hard drive name >> appears to be OK" then type reboot and hit RETURN. The iMac should restart and boot a repaired system.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I have tried multiple holding keys at power-on each combination for about 25-30 minutes each try until my fingers cramped. i actually put a weight on the shift key and let that go for a few hours. All with same result. Apple logo screen appears, hard drive crunches and the little wheel spins and never gets to text display or desktop. thanks for the suggestion. i may have to buy a copy of osx tiger or try a ubuntu boot disk and try repairing from within ubuntu.
tarafından
Yorum Ekle
Yanıtını ekle
ronf57 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 689
