Ana içeriğe geç
Fare, klavye ve monitör gibi çalışması için gereken üçüncül bileşenlerin dışında ana bileşenleri ayrı bir kasada bulunan, sabit, kişisel masaüstü bilgisayar.
542 Soru Tümünü görüntüle
Monitors doesn't receives signal.
I recently moved from Arizona to Illinois and the my PC was unplugged for about three week until it arrived in Illinois. When I tried to set up the PC it appeared have a boot loop issue. I was able to fix that by resetting the CMOS and it successfully turned on with all fans spinning. Then another issue happened where neither of my two monitors will work when connected to the mother board or video card. I tried switching the port of the video card itself and it still didn't work. I tried to see if my cable or monitors were the ones messed up but they connect to my atop just fine and receives signal. Then I totally removed my video card and tried connecting directly into my motherboard.
Update (06/01/2018)
ASRock Z270 Extreme 4 LGA 1151 Intel Z270 HDMI SATA 6Gb/s USB 3.1 ATX Motherboards - Intel
MSI GeForce GTX 1070 DirectX 12 GTX 1070 ARMOR 8G OC 8GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
Try removing, cleaning and reinstalling the memory sticks. Remove the dust with compressed air and reinstall again. Hope this helps :)
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
HI:
My guess is the computer is not running actually even with the fans running.
I would first unplug the power and hang on to the metal to relieve static many times as you do the following. You probably need a new cmos battery or check your battery has 3.3 v dc or what is written on the battery. Then pull the ram and reseat it, blow out the contact area, then remove the CPU cooler and re-seat the processor, we do not know what processor it is but the old ones have a lever to release the processor lift this and sort of carefully jiggle the processor, if a different processor the same idea if you can pick it out a bit with fingernails and let it back ( we are thinking in the move things were shook up some like a heavy bump) take your time and be cautious lock the processor back. the grease pad should be ok, I usually dab at it with a finger then when putting the cooling fan back sort of squiggle it on top of the processor, if the computer runs then think about going to get some new grease (it does not need much as it is just filling in the depressions between the processor and cooling fan plate so there is no voids in the contact where the heat can build up and not transfer the heat to the cooler.
Same goes for the power supply connection on the motherboard and hard drive connections.
You get the idea I am sure, to just re-seat all connections on the hardware.
Dust the inside and fans to assure of cooling, then hook up your external connections for the video and keyboard and mouse and give it a go. If the computer is actually running you should hear the hard drives whine up then pop goes your video we hope.
With all this you are not out any money yet and the hard bump in shipping still could have broken a trace on the motherboard so you are hooped. Oh forgot for you to have a good look at your capacitors on the board for bulging tops or other damage. I have had computers running then stop for a reset of upgrade and it is dead.
Good luck and please post how you are making out.
Alton
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
hedemanian sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 183
