Ana içeriğe geç
The Sony Xperia Z5 Android smartphone was released in October 2015. The Sony Xperia Z5 features 5.2 inches 1080 x 1920 pixels display and is equipped with a Qualcomm Snapdragon 810 processor alongside 3GB RAM and a 23 MP rear camera.
74 Soru Tümünü görüntüle
My Xperia Z5 premium doesn't turn on, and the red led flashing
gents, please help me how to fix my mobile phone.
my Xperia Z5 premium doesn't turn on, and the red led flashing while plug the USB cable.
force restart and power with volume keys not work.
also, tried to use Xperia Companion but unfortunately my phone not able to contact with the PC.
do anyone has any idea about what's happening?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
1 Yorum
Battery over discharged or given up. Have you plugged it in and left it for maybe an hour or so? Also try another charger/ cable if you can. If the phone is 2 or 3 years old the battery may need to be replaced.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I had a similar issue, couldnt fastboot, POWER+VOLUME KEYS did nothing for me. Changing the chargers had different effects from red flashes, 3 red flashes and at times white sony screen flashes.
So I took it to the local shop and when they opened up the back cover, they found out that the battery connector had come loose. After pressing it back in, the phone was back.
Hope this helps someone.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Did you tried turning it on, on fastboot?
-Just press the volume down (No power button)
-Plug the phone into the computer while pressing that key
A blue light should turn on
Puan 0
3 Yorum:
yes i did but no response
tarafından
You never got the phone wet? (I know the z5 is waterproof, but sometimes the seal fails).
tarafından
that's never happened mate
tarafından
Yorum Ekle
Just had the same issue.
Tried to charged using powerbank, as I thought charging from power outlet didn't work. FAIL.
Then i opened the simcard cover, pressed the yellow button & power button at the same time for couple of seconds. maybe 3-4 seconds. Last one, put it on charging cable.
Voila, it charges & back to life.
Puan 0
Yorum Ekle
Yanıtını ekle
eng.mo3taz_surv sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 69
Her zaman: 7,047
