Ana içeriğe geç
This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
103 Soru Tümünü görüntüle
Head lights work but no low beams
2002 Ford Escape. Hi beams are the only thing that work. Low beams don't. I have changed bulbs and fuses, and switch. Is there a way to find the hi beams until I can figure out what's wrong and fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
So either the light switch is bad or you may have a damaged wire. I would start using a volt meter to see if your getting power from the switch first then if that's okay start looking for a bad wire. Have you tested the bulbs to make sure they work. Using a jumper wire to the low beam wire to the battery will be an easy test to see the lights work
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Tracie Anne sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 292
