Ana içeriğe geç
Repair guides for displays (or monitors) for computers or other devices with video output.
502 Soru Tümünü görüntüle
Monitor only stays on when I hold down the power button
I have a HP L1950 monitor and it powers on okay but turns black after 1/2 second then lights up again after 5 seconds then turns black again. When I hold down the power button it stays lit for as long as I hold down the button but when I release the screen goes black again.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
'''++@liftnhop++''' most likely a bad power board. Common for that type of monitor. Disassemble it and check the power board the same way you would for a no power situation. Page 38 on here ManualsLib - Makes it easy to find manuals online!
If unsure about anything you can always post some images of your boards and we can try to help you out. Use this guide Adding images to an existing question for that
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Have you ever checked out the button itself. Its a switch and could be damaged. The replacement should solve that.
Puan 0
Yorum Ekle
Yanıtını ekle
Randall Baker sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 376
