Mackie cr4s only play sound through headphones
Ive had a pair of mackie cr4s for over a year now and cant say ive used them too much. When i went to use them last week they turned on but no sound was coming out, i plugged some headphones in and the sound played perfectly through them? I also noticed that when i turn them off by the switch on the powered monitor, sound will come out the speakers for a second before they turn off? Any help appreciated.
Update (06/12/2018)
Bu iyi bir soru mu?
8 Yorum
They look really dark when I uploaded them so I'm guessing they won't be much help
Day mcshay tarafından
Hi I have similar problem with Mackie CR 4, the sounds can only be heard trough headphones. Pls help with the issues, thank you.
Novel tarafından
OMG I have exactly the same Problem with Mackie CR 4 too.
Greetings from Switzerland
Davis 500 tarafından
Seems to be a well known problem with them. Just need to know how to fix it
I have the same problem too. For a while the sound came on briefly after switching on but no nothing except through the headphones. Mackie must be aware of this problem.
matthew ludman tarafından
3 tane daha yorum göster
