Whirlpool wdf520padw5 dishwasher not spraying
Hi All,
My whirlpool dishwasher does not seem to spray water. It fills with water and then does not do anything. When I clear it the drain cycle works fine.
I checked the float and it does not look like its stuck.
I switched it off and on. Did not work.
I cleaned the spray arms, did not help.
I took off the water filter and the screen and cleaned them. There was nothing in the basin at the bottom of the dishwasher under the screen.
When i opened the footplate and ran the dishwasher, I could hear a few soft clicks when it got stuck. Not sure if its from the inlet valve or the circulation pump?
I have run out of ideas. Please help!
Thanks,
Sagar
Bu iyi bir soru mu?
I have the same issue, water will fill (now that I replaced the water inlet valve) and I replaced the float switch. Nothing happens once the water has filled. I have cleaned both top and bottom stems as well as cleaned all screens on the bottom. Help me please!!
Jeff Landress tarafından
definitely not the circulation pump in my case since I replaced it myself. PARTS are so expensive to replace. Inlet valve works, drain switch works. I think its my motor but already spent 200$ on parts and don't want to spend $126 for a new motor.
Amit j tarafından
@Amit j ,
Check if there is voltage getting to the circulation pump motor terminals. if there is then it is the motor or the start capacitor if it has one - you didn't state the make or model number
jayeff tarafından
Heres the model number MDB4949SDE3 hmm didn't check that yet...didn't know that motor has a capacitor.
Amit j tarafından
In my case I ordered whole new one and thats not it. I didn't measure any dc voltage at 2 blue wires coming from motor to the circulation water pump.
Amit j tarafından
1 tane daha yorum göster
