Ana içeriğe geç
Bağımsız dondurucular için onarım bilgileri.
Freezer doesn't work properly. Not cold enough
My samsung upright refrigerator has the freezer in the bottom. It stopped working but the fridge part is working well. Actually the freezer becomes a fridge. Don't know why. We unplugged and kept it off for 24 hours, but problem still there. However, if we "power freeze", the freezer will work until we turn off "power freeze" button.
Not sure what to do by myself. Do I need to buy a new one?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
4 Yorum
Please give us a model number. Usually the freezer is used to cool the fridge.
tarafından
It’s Samsung RB196ACBP. And 7 years old.
tarafından
I have the same probleme inmy freezer
Beko RDNE500K21W
tarafından
freezer not cool not snow freez only working
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The most common cause for this condition is a problem with the defrost system.
I would replace the defrost thermostat: 5303918214 - Refrigerator Defrost Thermostat Kit
Includes clip, leads, and heat shrink for replacing the defrost thermostat in your refrigerator. Görseli
Ürün
$18.99
Bu yanıt yardımcı oldu mu?
Puan 3
8 Yorum:
Thank you. I will try to replace it by myself. Don’t know how to start. First locate the thermostat, then buy the part and replace it.
tarafından
is the right part in your link that I need to buy? Normally where is the thermostat? Thank you very much
tarafından
yes. that the correct part for your model. As to where it is, I think my link has a 2 min video of how to install it.
Yep, here it is: https://www.repairclinic.com/Video/Video...
tarafından
Thank yo mayer. I will give it a try
tarafından
HI Mayer, Just want to know, is this part you mentioned for my Samsung fridge. Should it be defrost thermostat DA47-00243K? my fridge isSamsung RB196ACBP
tarafından
3 tane daha yorum göster
Yorum Ekle
Take a look at this article:
https://www.networx.com/article/why-is-m...
Puan 0
Yorum Ekle
This problem recurs in my fridge/freezer and I resolve it by taking out the inner panel of the freezer compartment to expose the freezer unit at the back of the freezer. This unit ices up occasionally and becomes a solid block of ice, the result of which is to severely impair the function of the freezer. Defrost until there is no sign of ice between the freezer pipes and fins etc, replace the cover and switch on. In my case with a Beko freezer, this does the trick and it works like new after defrosting.
Puan 0
1 Yorum:
Thank you. i will try to melt the ice and replace the cover.
tarafından
Yorum Ekle
Yanıtını ekle
Min sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 1,580
