Ana içeriğe geç
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
113 Soru Tümünü görüntüle
Abs and TC lights come on when braking and turning at the same time?
In my 2006 Equinox the brake pads and rotors definitely need replaced but also the ABS and TC lights come on when braking while turning unless I break very very slowly. I pull over turn the car off and back on and the lights go off until it happens again. The brake pads and rotors need replaced and because of financial reasons I've had to put this off longer than should be. I'm just wondering if replacing pads and rotors will correct the problem with the anti-lock brake and tread control?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Had new brake pads put on my 1015 equonix. Now Amy ABS light comes on and off?? What caused this.?
Bu yanıt yardımcı oldu mu?
Puan 0
Yorumlar:
If brake pads were changed and then the light is going on and off, I would suspect that something may have caused the wire to the speed sensor to be cut or caused the connector to loose contact. I would have that checked out right away.
tarafından
Yorum Ekle
If your ABS and TC lights are coming on, then the wheel speed sensor is detecting something wrong. It is possible that badly worn brake rotors could be causing this fault. When the brakes get replaced, have them check your computer for issues with the brake system. There should be historical data recorded that will tell them if there is an additional problem.
Puan 0
Yorum Ekle
Yanıtını ekle
Heidi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 541
