Why my phone isn't charging?
my phone charging port is broken every time i charge my phone it lights up but its not charging and i need to know if it can but replaced.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Please be advised that you will need to remove the screen to do this . Take your time aplply heat to the screen with a hot air gun to loosen the glue holding it shut. You will also have to solder the new port to the board . This video shows the whole process https://www.youtube.com/watch?v=76QIweFh...
This person used kapton tape to isolate the area around the port so he could desolder using a heat gun . this was not really show well in the video . Kapton tape disperses heat so only the area you want heated gets heated. Hope this helps
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 248
