Ana içeriğe geç
Shark Rotator Powered Lift-Away XL Capacity, model NV755. It can convert from a push vacuum to a hand-held vacuum. Repairs and troubleshooting found here may also be applicable to models NV652 and NV752.
My wand won't release. How can I get it out?
The wand for my Shark Rotator Professional won't release. Is there something I can do to get it out?
Bu iyi bir soru mu?
Puan 9
4 Yorum
My sharks hose won’t stay down, it keeps slipping out of the place it’s suppose to stay in. Please help
tarafından
I twisted the handle a few times while depressing the button and it came out :)
tarafından
After multiple attempts, hitting the stuck wand from the side worked, so it was most likely misaligned. I suspect winding the cord tightly might pull the wand out of alignment. I'm going to do only a light winding going forward. Fingers crossed 🤞.
tarafından
the manual doesn't say to unwind the cord first. I tried for 30 minutes to get the wand released. Thanks for this info!
tarafından
Yorum Ekle
13 Cevap
Filtre ölçütü:
Seçilen Çözüm
First, unwind the cord from the machine and try to pull the wand again.
It is poorly designed, in that if you have the cord wound on the machine, it ties the 2 parts of the vacuum together.
If this doesn’t work, look at the space between the chrome pipe and the white plastic where the 2 pieces come together.
If the space isn’t even on both sides, the unlocking mechanism won’t work. Apparently there is just enough space where it will stick in and not come out. if it isn’t properly aligned.
You can try hitting it with your fist to push the larger spaced side in more, or if that isn’t enough power, take a small hammer and a block of wood and tap on it gently until it moves into the correct space.
Bu yanıt yardımcı oldu mu?
Puan 14
20 Yorum:
A Duh! moment for me. Unwind the the cord, so logical and it worked.
tarafından
Unwinding the cord fixed it for me too. I just bought this vacuum a few weeks ago and didn't realize this design flaw.
tarafından
Thank you so much! I feel like a dummy. Unwinding the cord worked
tarafından
I feel sooooo stupid! My husband and I both have been fighting for weeks to get the wand out....and for some reason only doing it before we plugged it in! Took the cord off the wand and it came out
tarafından
Worked for me. Just unwind the cord. Thanks.
tarafından
15 tane daha yorum göster
Yorum Ekle
When I chatted with Shark, “Robert” wanted to know the model number, serial
number, where and when I bought the vacuum (Rotator Professional), and what
I was wearing at the time. I think he was stalling because he has been
asked this questions many times and knows there’s a design flaw that can’t
be readily remedied. Ultimately, he told me I needed a new body and Wand.
I told him he was nuts.
The button went in and out, but the Wand remained stuck. Problem: the Wand
was not perfectly centered. Frank Zappa is the Mother of Invention. I used
a hammer. If you decide to bang the Wand (he said), hit the plastic not the thin
chrome metal because it will dent easily.
(Why the cord knows not to release the Wand if it is still wound on the unit is the
Mystery of Fatima.)
Puan 3
3 Yorum:
Thank you so much!!!! A Duh!!! Moment for me. Thank you, Thank you, thank you!!!😊
tarafından
My shark vacuum az1002 has the following problem: the handle with the power button won't click/go back in to the wand. Any ideas?
tarafından
Unbelievable. And I'm supposed to be good with machines.
tarafından
Yorum Ekle
I don't own this, but my research found this:
Twist The Telescoping Wand
Step 1
Grip the end of the telescoping wand where it meets the hose with one hand. Press in on the release button that is on the end of the hose with the other hand.
Step 2
Twist the end of the telescoping wand clockwise and then counter-clockwise while keeping the button depressed.
Step 3
Pull the wand off the hose while twisting it. Release the button once the wand is free of the hose.
Lubricate The Telescoping Wand
Step 1
Place a sheet of newspaper on the floor or carpet. Collapse the telescoping wand. Hold the hose so that the wand is facing down, over the newspaper.
Step 2
Place an end of the included plastic straw in the nozzle at the end of the lubricating spray can. Shake the can for five seconds.
Step 3
Spray a sustained burst of lubricating spray around the seam where the end of the wand and the hose meet. Remove the can once you have circled the seam.
Step 4
Keep the hose pointed down for two minutes and then grip the end of the wand with the other hand.
Step 5
Twist the end of the wand clockwise with one hand while twisting the end of the hose counter-clockwise with the other. Continue twisting until the wand comes free of the hose. Wipe both ends off with a paper towel. Throw the newspaper in the trash.
Pull The Telescoping Wand
Step 1
Unplug the vacuum cleaner's power cord from the wall outlet. Twist the section of the hose connected to the socket on the vacuum counter-clockwise to remove it.
Step 2
Collapse the telescoping wand, followed by collapsing the hose. Hold the two horizontally with the open end of the hose facing left and the wand facing right.
Step 3
Press the release button at the end of the hose next to where the wand is, providing there is one, with your left hand. Hold the hose steady while twisting the end of the wand away from you with the other hand.
Step 4
Continue to twist the wand while pulling it toward your right. Stop twisting the wand once it comes off the end of the hose.
Step 5
Release the hose button, if there is one. Return the hose to the socket on the vacuum cleaner.
SOURCE: https://www.hunker.com/13409428/the-tele...
Puan 0
2 Yorum:
mine wont stay back in what am i doing wrong?
tarafından
What's the directions say?
tarafından
Yorum Ekle
There are two types of wand release. The upper and the lower part of the wand. The lower one has a release right behind the handle of the wand. It has wand release written right on top of the button. If there’s nothing broken beyond this button it should come right off. The upper wand release is in front are the vacuum right below the handle. Press the button and lift the top handle out where it’s very easy.
Puan 0
Yorum Ekle
That is not a wand release. The only wand release is the button marked as such.
The other button you mention is simply to release the very top piece, the wand will still be in the vacuum.
I assume you have unwound the cord and that isn’t your problem?
The next thing to do is to grasp the chrome part of the wand, hold onto the main part of the vacuum and try to twist it slightly.If you have someone else to hold it, so much the better. If it isn’t the cord, in my experience, it is just ever so slightly out of wack where it connects on the bottom. Try twisting one way, then the other and try the release button again.
Puan 0
2 Yorum:
I had the same problem. I read all the answers from everyone on how to possibly resolve this issue. I did the following to fix this. I first removed the upper motorized unit from the wand using the top release button. That left the wand still attached to the floor unit. I then pushed lower release button where the remaining wand was attached to the floor unit. With the motor's weight off the wand, the wand easily release from the floor unit. This works every time so far. After using the vacuum, I place the wand in the floor unit before I reattach the vacuum motor unit back to the wand.
tarafından
I am having trouble getting the wand to click into place
Any ideas will be greatly appreciated
Diana
tarafından
Yorum Ekle
I have same problem and looks like there is no solution!!
Puan 0
1 Yorum:
On the left side of the wand where it goes into the throat of the base there is a tab that's supposed to release when you push the wand release button. That button doesn't seem to be working anymore on my vac but pushing in that tab with the handle of a screwdriver worked for me.
tarafından
Yorum Ekle
Unwind the cord first, then pull the wand.
Puan 0
2 Yorum:
how do you get it to stay back in mine wont stay in after i take it out???
tarafından
Or mine have u solved this issue I’ve only had it a week and half
tarafından
Yorum Ekle
I had this same problem too with the lift away… after reviewing different suggestions here…. I unwrapped the cord first, then released the tube. Works fine now. ?‍♀️
Puan 0
Yorum Ekle
I have read the posts here and clearly there are 2 main solutions to why this question is asked. Most of the people apparently didn’t realize that the cord needs to be removed from it’s latch in order to remove the wand since they are connected. The problem I had was much more difficult to solve though I did and brought pictures to share for anyone else who hasn’t been able to resolve their issue.
In my case I suspected the release latch mechanism on the inside was broken and when I took it apart I found that I was correct. Use the photos to determine if this is the same model as yours.
First, I removed all the screws that attached the back plate. Some screw in from the back, a couple from the front, and 2 from the bottom. This will remove the back which will remain connected by a few wires while still granting you sufficient access to the problem area. Press your release latch and you can see the offending plunger with a broken plastic pad preventing it from releasing the wand. There is a spring holding the latch in place. Remove or disable this spring to release the wand.
Keep in mind that disabling the wand release will render your vacuum unable to properly operate in upright position without a little rigging such as using a stretchy band to connect the cord wind up location together. So the solution will be exactly the problem those first group of people had which prevented them from releasing the wand.
I hope this solution helps.
Puan 0
Yorum Ekle
With some of the comments on here, it's no wonder tRump was elected president!
Puan 0
Yorum Ekle
Unwinding cord worked for me too. TYVM
Puan 0
Yorum Ekle
If I have to I'll count my wands and see how many of them work.
Puan 0
Yorum Ekle
My wand stick is stuck how do I get it put
Puan -1
1 Yorum:
I can not get my wand to click back in to lock it on I have the lift away any help
tarafından
Yorum Ekle
Yanıtını ekle
melindan2 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 26
Son 7 gün: 111
Son 30 gün: 532
Her zaman: 51,680
