iPhone 5s has a vertical unresponsive line after screen replacement.
My iPhone 5s display had some randomly appearing ghosting issues after the battery replacement so I replaced also the display but afterwards I had an unresponsive vertical line of about 5 mm in about the middle of the screen. The rest of the digitizer area and display works fine though.
I checked with a second replacement Display and it had the same problem.
But when switching back to the original display, the display and digitizer works fine. Expect that at sometimes the ghosting appears.
Anyone with similar issues? Could it be a problem with the connector of the new displays? But I don't understand why the original does not have this problem.
Bu iyi bir soru mu?
I tested a bit more and the unresponsive line appears after a few minutes after restart of the phone. Before everything works but then a small portion of the digitizer stays unresponsive till the next restart. Maybe some kind of potential is build which causes malfunction is a certain part of the digitizer?
Andi tarafından
